June 20, 2019 at 4:24 pm
zqclucky
SubscriberHi,
I am trying to sweep the surface along a curve to generate the body. But I cannot find that function when I press "extrude" button. Is it because the fluent V19.2 in my computer is a student(academic) version?
Best,
Qiaochu
June 20, 2019 at 4:52 pm
Forum ModeratorNo. The tool is in DesignModeler though, not Fluent.
June 20, 2019 at 5:37 pm
June 21, 2019 at 11:02 am
Forum ModeratorI think you've mucked up the interface settings. Go to File -> SpaceClaim Options -> Appearance and use the "Reset Docking Layout" button.
I'll move to pre-proc too as this isn't really a tutorial question.
June 21, 2019 at 4:41 pm
zqclucky
SubscriberThank you for your reply, but it still does not work. When I press "pull" button, still no option shows up on the left top corner of screen.
June 21, 2019 at 5:55 pm
June 21, 2019 at 6:12 pm
June 21, 2019 at 9:28 pm
peteroznewman
SubscriberYou have a defective installation. Here is a procedure that will create a new profile for you. Quit ANSYS.
Open Windows Explorer. In the text field type %appdata% and you will see a list of folders. One of them is ANSYS. Rename this to ANSYS_old. Start ANSYS and see if this fixed the problem.
If that didn't fix the problem, you can try to uninstall ANSYS and reinstall it.
October 20, 2023 at 12:50 pm
iyyappan ramasamy
SubscriberI am not able to do this. How do i create a circule and trajectory. In the same XY plane or circle in one plane for example YZ and trajectory curve XY? This sweep function is not working if i do that way. can some explain from scratch?
October 21, 2023 at 10:48 am
- The topic ‘Sweep the surface along a curve’ is closed to new replies.
3301
1036
1006
859
804
