Preprocessing
Preprocessing
Surface to Surface Radiation in a Small Wedge
    • Jonahbt40
    • Rahul Kumbhar
      I would suggest to ignore the surfaces in the wedge. Split the faces which are part of wedge and only select 6 faces of the cavity. You can add contact between surfaces in the wedge to for the conduction.n
  • The topic ‘Surface to Surface Radiation in a Small Wedge’ is closed to new replies.
