Preprocessing
Preprocessing
Surface not Solid problem
    • Aya
      When I am importing the geometry in the design modeler, it gave me surface bodies, not solids.
      How can I solve this problem and transfer my geometry to solids.
      Please find my attached photo.
      I suspect the CAD came in as separate surfaces and they've failed to connect to form a solid body. Have a look at the geometry to see what's going on. n
    • Aya
      Ok, I will check the cad file. n
    • Keyur Kanade
      Please check if any face is missing. nCreate that face in DM. Then use Stich operation to create solid in DM. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • Aya
      Thanks for your reply nIt worked with me. Thanks a lotn
Viewing 4 reply threads
  • The topic ‘Surface not Solid problem’ is closed to new replies.
