Surface Equation Generation not Showing Up in Ansys Discovery Script Editor
September 26, 2024 at 12:54 pm
September 26, 2024 at 3:11 pm
Atharv Joshi
Forum ModeratorHello,ÂÂCan you try this without ClearAll() command?ÂI think its deleting the custom surface that's created and thus failing to find any face for selection.ÂÂRegardsAtharv -
September 27, 2024 at 1:54 pm
Atharv Joshi
Forum Moderator-
September 30, 2024 at 9:57 am
nv221
SubscriberThank you for responding, but it's still not working. I think the surface that is being created is not shown in the script editor and so when there are any operations that select that body, it doesn't work. I was wondering if there were any settings that I need to edit or if there was another way to get that surface to show up in the script editor. I want to later embed this script and parameterise this for automation.Â
October 9, 2024 at 1:25 pm
Atharv Joshi
Forum ModeratorHave you treid after removing the ClearAll() command? Do you surface created in Model Tree?Refer to my first image where you can see Radial Wave surface in the model tree.ÂPlease check the above images. First create a surface, you should see surface created in Model Tree.ÂThen run the scriipt as shown in the editor.ÂRegardsAtharvÂ
1890
1414
1303
