November 29, 2019 at 1:50 am
KevinsYuan
SubscriberHi everyone,
i find out this option (Modell - Geometry - insert "Surface Coating") here, can anyone tell me what is the meaning of "Suface Coating" in Ansys?
I just intressted about the stress underneath the coating, will the result be the same with a real geometry (in [um] thin) of surface coating if i use this option. The thickness of coating is to small relative to other parts, for example 5 um vs. 20 mm, sothat i have difficulty to mesh the entire part.
Thank you very much!
Reguard
Kevin
November 30, 2019 at 3:45 pm
peteroznewman
SubscriberPlease read this page of the ANSYS help.
Please read this Discussion about how to use the link above.
The answer is yes, you can get the effect of a thin coating of some other material to a specified thickness on top of a solid body. You can look at the stress on the surface of the solid as well as the surface of the coating.
July 8, 2023 at 8:05 am
Shantanu Khawas
SubscriberCan we use surface coating technique to study the heat transfer efficiency of a coating on a geometry?
- The topic ‘Surface coating meaning’ is closed to new replies.
