July 17, 2023 at 2:13 pm
ae22b001
SubscriberHello, Im trying to simulate the shock train in a supersonic inlet. I have attached a picture of my mesh.
Inlet - Pressure inlet - Total Pressure = 207Kpa, Static Pressure = 42Kpa (Mach 1.7) Total temp = 310K
Outlet - Pressure outlet - Static pressure = 1 Pa
Im supposed to get a nice series of shocks in the duct. However when I run the simulation, I find that initially the shock forms, with more iterations the location of the shock moves towards the inlet and disappears, Once it disappears the solution converges immediately.
How do I solve this problem?
July 17, 2023 at 5:29 pm
Federico
Ansys EmployeeHello,Â
Which solver are you using? Pressure or Density-based? Which Solution methods and discretization schemes are you using?
can you show us a contour plot for the pressure? If you can, please include a snapshot of the intermediate solution (with the shocks) and the final solution.
July 18, 2023 at 4:44 am
ae22b001
SubscriberHello, Thank you for your reply.
I am using the pressure based solver with coupled method and 2nd order discretization schemes. I also tried the density based solver, but it seems to take a lot more iterations to get to the same point.
After 150 iterations:500 iterations:
Converged solution:
Residuals drop sharply after the shock disappears and the inlet which was supersonic initially becomes subsonic.
Inlet was suppose to remain at mach 1.7 but after the shock disappears it becomes subsonic.
Kindly help, thanks.
July 18, 2023 at 5:26 am
ae22b001
SubscriberHello, thank you for your reply.
I am using the pressure-based solver with coupled method and 2nd-order discretization schemes. I have also tried the density-based solver, but it seems to take many more iterations to get to the same point.
I have attached the contour plots and residuals.
Also, after the shock disappears, the inlet becomes subsonic, which is not what I set.
After fmg initialization:after 150 iterations:
After 300 iterations:
After 500 :
Residuals and inlet Mach number:
Kindly help, Thanks
July 18, 2023 at 1:13 pm
Federico
Ansys EmployeeWhat are your operating conditions?
Given your boundary conditions, are you sure that the nozzle exit is not choked?
July 18, 2023 at 2:14 pm
ae22b001
SubscriberÂ
Operating pressure = 0 Pa
I’m referring a research paper that has experimental data. The outlet was connected to a vacuum pump so that’s why I set the outlet pressure to close to 0. How do I fix this? So I don't think it is choked.Â
July 19, 2023 at 4:55 am
ae22b001
SubscriberHello everyone, Any suggestions would be really helpful, Thanks.
- The topic ‘Supersonic Shock Train’ is closed to new replies.
5754
