July 2, 2025 at 2:32 pm
msm19b039
SubscriberHello moderators and fellow CFD enthusiasts.
For the past 3 week I have been trying to estimate the suction lift of a pump but to no avail. Suction lift is the time it takes for a pump to lift water from the sump through a pipe. I have run performance tests on pumps so I have an understanding of the dynamics of the problem however I believe now is the right time to ask for help from the experts in the field.Â
I will try to describe my problem in the simplest way possible. I have a pump geometry, the inlet of which is connected to a vertical pipe of 3m and I wish to determine the time it takes for lifting water by 3m in a transient mesh motion analysis. Attached below are the images of the geometry and the BCs.
Fundamentals first, I have carried out rotary simulations before so the basic BCs are right. I have 3 domains, the pipe, the stationary volute and the rotational domain containing the impeller. Impeller is a moving wall with 0 velocity relative to the adjacent moving cell zone. I have given 0 Pa gauge pressure inlet at the pipe inlet. There is an interface between the pipe and pump inlet which is treated as interior and also an interface at the stationary/rotary domain. Outlet as well i have given gauge pressure 0 Pa pressure outlet.Â
Now, the working principle of the pump is that initially it is primed with water and the pipe is empty(air). So I proceeded with Multiphase approach VoF model Implicit dispersed scheme and enabled all the necessary stabilization schemes as suggested in 'VoF check' during initialization phase. Henceforth, I patched water in the pump and air to the pipe with the pump inlet/pipe interface acting as phase interface. There's a caveat here. In real life, there is an NRV present at the pump inlet which opens up as suction pressure builds up when the impeller starts rotating. The cracking pressure of the NRV is 20000 Pa and full open is 50000Pa. Hence, I enabled the porous zone for the pump body and decided that inital porosity can be 0.05 and I will increase it as the aforementions required pressure values are reached.Â
Also, I read that for multiphase flows and flows where hydrostatic pressure is crucial (like in mine) we have to enable operating density and assign a value of zero(is this correct?). My operating pressure is 101325Pa(is this correct?) and reference pressure location is (0,0,0) which is outside the domain (does this have an effect?. I did change it and so no effect)
Now the issue I'm facing is that as soon as i start the simulation, a very high -ve absolute pressure is seen across the domain which i believe is due to the porous zone inclusion. As the impeller starts primed water gets sucked into it and there is no fluid to take the place and this results in vaccumm?. I also tried patching 0.7 Volume fraction water and 0.3 air to the pump but that did not yield anything. Sometimes I see a very high +ve absolute pressure but the total pressure from surface integral at outlet reads 0Pa gauge. I tried with no porosity and it works just fine with pressure dropping and water getting lifted from the pump inlet but that would be totally wrong as s it doesn't account for the nrv behaviour which has a great say on the results.
I also tried by modeling with delivery pipe(do you think modeling the delivery pipe is neccesary?) and patching air to it, water to pump and air to suction pipe but to no avail. It just doesn't work with the porous zone inclusion. I have a good quality, decent density 2.2M mesh and I have also tried lessening the time step size.
I thinK I'm missing something very intuitive here.
PLEASE ADVISE as this has become a very painstaking activity for me with countless sleepless nights.Â
July 3, 2025 at 2:54 am
msm19b039
SubscriberForum moderators could you please reply
3492
1057
1051
965
942
