September 8, 2022 at 11:45 am
r10543101
SubscriberHello
When I use fluent in workbench
Geometry and Mesh both work fine
But in the Set step, it does not work properlyThe message in the Set console
       Welcome to ANSYS Fluent 2022 R2       Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.       Unauthorized use, distribution or duplication is prohibited.       This product is subject to U.S. laws governing export and re-export.       For full Legal Notice, see documentation.ÂBuild Time: May 27 2022 08:52:29 EDT Build Id: 10212 ÂÂConnected License Server List:   --------------------------------------------------------------   This is a student version of ANSYS FLUENT. Usage of this product   license is limited to the terms and conditions specified in your ANSYS   license form, additional terms section.   --------------------------------------------------------------Host spawning Node 0 on machine "LAPTOP-KN02JFQD" (win64).Â====================================================================================  BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES=  RANK 0 PID 29344 RUNNING AT LAPTOP-KN02JFQD=  EXIT STATUS: -1073741515 (c0000135)===================================================================================Â====================================================================================  BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES=  RANK 1 PID 18396 RUNNING AT LAPTOP-KN02JFQD=  EXIT STATUS: -1073741515 (c0000135)===================================================================================Â====================================================================================  BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES=  RANK 2 PID 11968 RUNNING AT LAPTOP-KN02JFQD=  EXIT STATUS: -1073741515 (c0000135)===================================================================================Â====================================================================================  BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES=  RANK 3 PID 4568 RUNNING AT LAPTOP-KN02JFQD=  EXIT STATUS: -1073741515 (c0000135)===================================================================================ÂWhen I turn back to the workbenchIt says" Fluent Application cannot be verified to connect"Why is this happening?
I need to finish my master's thesis urgently
Thank you..!Â
ÂÂÂÂ
September 8, 2022 at 12:34 pm
George Karnos
Ansys EmployeeCan you try turning off your firewall software to test if something is being blocked?
September 9, 2022 at 10:45 am
r10543101
SubscriberSorry, I try turning off my firewall .
But it's still doesn't work.
September 9, 2022 at 3:21 pm
George Karnos
Ansys EmployeeIs this a new installation, or did it work before?
Do any errors exist int the install.log located under:
C:\Program Files\ANSYS Inc\ANSYS Student
Or, does an install.err exist? What is the contents? -
September 10, 2022 at 5:20 am
r10543101
SubscriberAt the beginning of the download can be used, after using a month this happens.
The following content is found in the folder:
Â>>>--------------------------------------->ANSYS安装: 週四 八月 25 12:21:12 2022版本: 2022 R2  ###### Error #######  Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\framewrk\WINX64.7z:  '"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\framewrk\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):    Unknown error  Exit Code: 2  ###### Error #######  Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\cpythnew\WINX64.7z:  '"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\cpythnew\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles"' terminated after 1 attempts with the following error(s):    Unknown error  Exit Code: 2  ###### Error #######  Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\tp\IntelCompiler\WINX64.7z:  '"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\tp\IntelCompiler\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):    Unknown error  Exit Code: 2  ###### Error #######  Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\tp\intelmkl2021.3.0\WINX64.7z:  '"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\tp\intelmkl2021.3.0\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):    Unknown error  Exit Code: 2  ###### Error #######  Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluents\WINX64.7z:  '"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluents\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):    Unknown error  Exit Code: 2  ###### Error #######  Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluenta\WINX64.7z:  '"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluenta\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):    Unknown error  Exit Code: 2  ###### Error #######  Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluentp\WINX64.7z:  '"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluentp\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):    Unknown error  Exit Code: 2  ###### Error #######  Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluent3ddp\WINX64.7z:  '"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluent3ddp\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):    Unknown error  Exit Code: 2>>>--------------------------------------->ÂPlease take a look.Thank you.ÂÂ
September 15, 2022 at 2:52 am
r10543101
SubscriberSorry, is there a way to solve this?
September 16, 2022 at 8:51 am
June 19, 2023 at 7:04 am
Ashagoni Nivas
SubscriberHello
Build Time: May 27 2022 08:52:29 EDT Build Id: 10212Â Â
Thank you..!
- The topic ‘student licensing error’ is closed to new replies.
5094
1830
1387
1248
