October 18, 2024 at 12:43 am
c3398477
SubscriberContinually running into this error when launching fluent, can launch from the workbench with no issues but not on it owns. Following error:
Connected License Server List:
Unexpected license problem; exiting.
Hit return to exit.
Also, when running CFD-Post I get this error:
So far I have tried unintsalling and redownloading the entire package, unconfiguring and reconfiguring using Productconfig.exe
I am out of ideas.
October 18, 2024 at 12:05 pm
George Karnos
Ansys EmployeeAfter uninstalling, did you remove the directory
c:\Program Files\Ansys Inc\
Try the following:
Uninstall, rename c:\Program Files\Ansys Inc to c:\Program Files\Ansys_Old
Reinstall. -
October 19, 2024 at 2:48 am
c3398477
SubscriberI tried it that way and the application opened fine the first time but now it has gone back to showing the error and failing to launch
October 19, 2024 at 2:51 am
c3398477
Subscriber -
October 22, 2024 at 4:48 pm
George Karnos
Ansys EmployeeTry the following:
rename the v242 directory that is under:
%APPDATA%\Ansysto v242.old
now try to run.
If that doesn't work, check firewall software. Try disabling it for a test. then try to run.
Check firewall logs to see if it is blocking the program from checking out a license. -
October 27, 2024 at 5:16 pm
amrishsekar
SubscriberI have the same issue let me try the %APPDATA%?Ansys
October 27, 2024 at 5:26 pm
amrishsekar
Subscriberthat doesnt work
6109
