November 2, 2022 at 2:42 am
November 11, 2022 at 4:39 pm
Nikhil N
SubscriberÂ
Hello,Â
Please check this thread: Fluent Failed to validate connection (ansys.com)
In that thread, you may want to try out few suggestions/workarounds from the user itself and see if that works.Â
Nikhil
November 12, 2022 at 10:02 am
m.yusqishoubil
SubscriberHello,Â
Previously, thank you very much for your response. I just tried to do all that you suggested to me. But, my Ansys software still won't start properly and the program just shows me the same problem which is Failing to validate the connection. Any other way to solve this problem or maybe I could use Ansys Cloud computing? Thank You Very Much
Yusqi
- The topic ‘The FLUENT application failed to validate the connection.’ is closed to new replies.
1890
1419
1304
