March 8, 2024 at 7:57 pm
March 11, 2024 at 2:53 pm
Essence
Ansys EmployeeÂ
Are you using Ansys/Workbench meshing? If yes, then while selecting the edges, select all the edges around the airfoil which are perpendicular to it by completing a full sweep around the airfoil.
March 11, 2024 at 4:00 pm
Tom Davies
SubscriberYes i am using workbench meshing. I have an edge sizing on the main surfaces of the Aerofoil and the circle around it. With another edge sizing on the front face of the Aerofoil (sharp corners) and the yellow circle which is going to be a moving mesh
March 11, 2024 at 4:13 pm
Essence
Ansys EmployeeYou also need to select the upper and lower curves (edges) of the aerofoil to apply the edge sizing to them.
March 11, 2024 at 4:23 pm
Tom Davies
SubscriberYes, sorry, I meant main edges not main surfaces. There is edge sizing in the upper and lower edges.
- The topic ‘Struggling to achieve mapped meshing’ is closed to new replies.
