March 25, 2024 at 3:09 pm
Rens van der Nolle
SubscriberI want do to a topology optmization to minimize warpage on a surface when there is a thermal load. is this possible?
I have made a steady-state thermal analysis, added a heat flow as temperature input. I also made a static-structutal anaylis with imported body temperature load. This analysis calculates the strain.
now when i add a structural optmization i get the following error:
"Structural Optimization does not support linked Static structural analysis which consists of temperature dependent material along with thermal loads."
Is there a way to get this done?
March 26, 2024 at 11:24 am
March 27, 2024 at 6:58 am
Rens van der Nolle
SubscriberDear Ashish,
With this thermal condition i get the same error: "Structural Optimization does not support linked Static structural analysis which consists of temperature dependent material along with thermal loads."
I even removed the thermal analysis and removed every link.
- The topic ‘Structural Optimization does not support linked Static & Thermal’ is closed to new replies.
4678
1565
1386
1242
