August 9, 2018 at 8:57 am
Saikishan
SubscriberHow can you apply both thermal and structural load at the same time for the same model . The model could be a cylinder -
August 9, 2018 at 12:17 pm
peteroznewman
SubscriberIf you just want to raise the temperature of the whole cylinder so that it can have thermal expansion against mechanical supports, like a shrink fit, you can do that right in Static Structural by adding a Thermal Condition, and enter the new temperature. The starting temperature is set in the Environment Temperature.
If you want a complicated thermal analysis that results in a temperature distribution over the part, you use two systems, and link the solution from the Steady State Thermal model as a load on the Static Structural model. In this example, they share the same mesh.
August 23, 2018 at 1:05 am
Sandeep Medikonda
Ansys Employee Saikisan,
 Check out some of these resources:
https://www.youtube.com/watch?v=Ktv7bYewakM
Sandeep
November 13, 2022 at 7:15 pm
nehna S
SubscriberI developed a model with thermal and static structural analysis. Its a beam having axial and rotation restraints. The restraints were provided using spring elements. How can i get the axial force v/s temperature curve of the beam.
- The topic ‘Structural and Thermal analysis’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1414
1221
1118
1015
