February 27, 2021 at 6:12 pm
wtorres
SubscriberHello Everyone !
How can I get stress Sx in Beam188 or Beam189 with ETABLE in ANSYS APDL?
I have used the following commands, but it did not work. ANSYS APDL always return stress section in the first node.
sb1 = 100
*DIM,SX_MAX,,sb1,1
*DO,e,1,sb1
SET,,, ,,, ,e
   ETABLE,S,LS,1,MAX
   *VGET,SEQ,ELEM,1,ETAB,S, , ,4Â
    SX_MAX(e,1) = SEQ(1,1)
ETABLE,REFLÂ
*ENDDO
When I define a rectangular profile section the above code work, but to irregular section does not work.
March 10, 2021 at 11:40 amRahul Kumbhar
Ansys EmployeeCan you check what is keyopt(15) setting for the irregular shape? If the keyopt(15)=1 then you wont be able to see the above results.nMarch 10, 2021 at 12:40 pmwtorres
SubscriberHi Array, yes I can, I checked, keyopt(15) = 0n KEYOPT(15nResults file format:n0Â --Â Store averaged results at each section corner node (default).n1Â --Â Store non-averaged results at each section integration point. (The volume of data may be excessive. This option is typically useful for built-up sections with multiple materials only.) nnThanksnViewing 2 reply threads- The topic ‘Stress Sx in Beam188/189’ is closed to new replies.
4683
1565
1386
1242
