February 6, 2024 at 9:27 am
huhminnyoung
SubscriberEven if the load and boundary conditions are the same in a workbench static structure, the stress results change slightly as the load step increases.
What is this about? -
February 6, 2024 at 10:06 am
Akshay Maniyar
Ansys EmployeeHi,
Can you share more details about the model? It will help to understand the issue and help you effectively.Â
Thanks,
Akshay Maniyar
February 6, 2024 at 11:09 am
huhminnyoung
SubscriberThe model is a pressure vessel receiving bolt pretension.
Bolt pretension was applied in step 1, and steps 2 to 4 were secured with locks.
Internal pressure was applied in step 3 and no conditions were changed in step 4.
However, the analysis results of steps 3 and 4 were slightly changed.
I wonder what the reason for this is.
February 6, 2024 at 11:08 am
huhminnyoung
SubscriberThe model is a pressure vessel receiving bolt pretension. Bolt pretension was applied in step 1, and steps 2 to 4 were secured with locks. Internal pressure was applied in step 3 and no conditions were changed in step 4. However, the analysis results of steps 3 and 4 were slightly changed. I wonder what the reason for this is. -
February 6, 2024 at 12:53 pm
Akshay Maniyar
Ansys EmployeeHi,Â
Can you share some inline images of the model? Also, how much is the difference in the result?
Thanks,
Akshay Maniyar
February 6, 2024 at 12:56 pm
huhminnyoung
SubscriberI'm sorry. Uploading images is difficult due to security concerns.
February 6, 2024 at 1:46 pm
Akshay Maniyar
Ansys EmployeeHi,Â
How much is the difference in result? Check for contact tool results, if it solving for the penetration which is changing the results.
Thanks,
Akshay Maniyar
February 6, 2024 at 11:36 pm
huhminnyoung
SubscriberThe difference is not significant, less than 0.1%. However, since all conditions are the same, I expected the exact same results to come out, but it is surprising that the results are different.
February 7, 2024 at 6:16 am
Akshay Maniyar
Ansys EmployeeHi,
It might be changing as for some contacts solver might be trying to reduce penetration allowed with more substeps.Â
Thanks,
Akshay Maniyar
February 7, 2024 at 6:43 am
huhminnyoung
SubscriberCould frictional contact be that kind of penetration?
Thanks for your reply.
- The topic ‘Stress result changes according to load step’ is closed to new replies.
5824
