November 27, 2024 at 5:58 pm
November 30, 2024 at 10:59 am
javat33489
SubscriberMaybe it is possible to assign a TYPE ID to a beam connection? So that later the results can be displayed in USER DEFINED RESULTS using this ID?
November 30, 2024 at 4:56 pm
dlooman
Ansys EmployeeThat might work. Commands like the ones below could be inserted into the connections
et,1001,188Â
esel,s,type,,_bid
emod,all,type,1001
allsel
Or there might be a way to create an APDL component of the elements for each beam diameter and reference the component name in the user defined result.
December 6, 2024 at 5:43 pm
javat33489
SubscriberThank you sir!
