August 28, 2024 at 3:14 pm
Tim Dukes
SubscriberHi SupportÂ
Is there a limit on rpm for rotating fluid zone?
It seems when using higher rpms to simulate a fan for example you get temperature results that seem very high.
Best Regards,
Tim Dukes
August 29, 2024 at 6:11 am
Devendra Badgujar
Forum ModeratorHi Tim,Â
Are you seeing any warning/error message? Also, is this MRF with CHT case?
DevendraÂ
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1495
1386
1209
