September 24, 2018 at 10:00 am
September 24, 2018 at 10:05 am
mekafime
SubscriberHi, do you activate "large deflections on" in Analysis Settings?
September 24, 2018 at 10:42 am
balsaidi
SubscriberHello Mekafime,
Yes I did turned large deformation on.
Bashir
September 24, 2018 at 2:00 pm
September 24, 2018 at 2:08 pm
September 25, 2018 at 3:33 am
balsaidi
SubscriberThanks Peter and Sandeep,
I am using Polyethylene plastic in my research. Is there any way that I can achieve the S.S. curve computationally? I am looking to identify the elastic region of Polyethylene.
Bashir
September 25, 2018 at 3:40 am
Sandeep Medikonda
Ansys EmployeeI don't quite understand why? Elastic properties are easily available online/from engineering data just plot it based on the youngs modulus and yield stress?
If you want to look at it computationally/back calculate, use a single (unit) element model and subject it to uni-axial displacement by constraining the 3 faces on the sides in x, y an z directions as needed to properly constrain all rigid body motions. Get the force-displacement or stress-strain curves from that to verify?
Sandeep
September 25, 2018 at 3:53 am
balsaidi
SubscriberSandeep,
Do you mean deriving S.S. curve from nominal stress? I did it for shear stress test, not sure if I did it right but still unable to define the end of elastic region!
I would be grateful if you have something to share with me regarding the nominal stress testing method?
Bashir
September 25, 2018 at 4:15 am
Sandeep Medikonda
- The topic ‘Strain-Stress curve’ is closed to new replies.
3597
1208
1092
1068
952
