TAGGED: cfd-post, custom-field-function, fluent, inviscid-flow, strain-rate
September 3, 2021 at 5:19 pm
Prem1996
SubscriberHow to calculate the strain rates using Fluent, specially when solving a Euler's equations? Solving Euler's equation means solving for Inviscid flow, where shear stresses are zero due to the zero viscosity ( the strain rates are not zero) However, Fluent is not allow me to calculate the strain rates (or maybe I am doing it wrong). Does any one know how to calculate the strain rates (such as del u / del y, del v/ del x) or the second derivative of the strain rates?? I tried using the custom field variable but since, I am solving for Euler's equation, fluent won't allow me to calculate the derivative functions using custom field functions nor I can calculate those using CFD-Post. Could someone help me with that please??
Thank You.
Prem.
September 3, 2021 at 6:52 pmAmine Ben Hadj Ali
Ansys EmployeeUnder Derivatives.
September 3, 2021 at 8:28 pmPrem1996
SubscriberThank you for the response.
Could you please explain it little further. Like where can I find the option "Derivatives" ?
Thank You.
September 6, 2021 at 6:43 amaitor.amatriain
SubscriberField Functions -> Custom -> Field Functions -> Derivatives
September 6, 2021 at 9:13 amAmine Ben Hadj Ali
Ansys EmployeeDerivatives is like Velocity is a category of Variables being available for post-processing.
September 9, 2021 at 7:17 pmPrem1996
SubscriberThank you for the response But I can't see "derivatives" options over there. The last option I can see is the "residual" one not the "derivative" one.
Are there any other option to Calculate those?
Thank You.
Prem
September 9, 2021 at 7:26 pmPrem1996
SubscriberThank You for the response. But since I am solving for the Euler's equation (Inviscid Flow) this "Derivative" variable category seems to be vanished from the post- processing as well as from the fluent. I checked out all the variables and properties those variables have but din not able to locate the "Derivative" variable option. Instead of choosing inviscid model, if I choose the different physical model such as Laminar flow with very low viscosity then I can locate the "derivative" variable option over there. But not for the Inviscid physical model (Calculating for Euler's equations) I don't the reason behind that.
Anyways Thank You for your help. I appreciate that.
Thank You.
Regards Prem.
September 10, 2021 at 6:35 amAmine Ben Hadj Ali
Ansys EmployeeYou can still access them in Fluent directly after telling Fluent to "Keep temporary solver memory from being freed?" /solve set expert (TUI). Reconstruction gradients are then accessible.
September 12, 2021 at 3:17 pmPrem1996
SubscriberThank You for giving me the solution. Could you please elaborate more like how I can do this??
Thank You.
Regards Prem
September 13, 2021 at 6:48 amaitor.amatriain
SubscriberIn the Fluent Console, write solve/set/expert, and then answer Yes to the question "Keep temporary solver memory from being freed?"
Viewing 9 reply threads- The topic ‘Strain rates in Inviscid flow (Euler’s Equation )’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3892
1414
1256
1118
1015
