LS Dyna
LS Dyna
STRAIN RATE MATERIAL MODEL
    • euklidespl
      To simulate sheet metal forming, I need to use the mat_242 (barlat & yoshida) material model. The problem is that the material model does not take into account the effect of deformation speed on stress. Is it possible to “work around” this problem without having to create my own material model?
    • Erik Kostson
      Hi
      Not sure about a workaround, but perhaps the below documents help:
      https://lsdyna.ansys.com/metal-forming/#:~:text=Material%20Model,MAT_244:%20MAT_UHS_STEEL
      MAT_­133: MAT_­BAR­LAT_­YLD2000 is similar and has strain rate effects
      Also there are many other material model that should perhaps include strain rate effects.
      All the best
      Erik
