Electronics
Electronics
Storage limit exceed
    • shupengli2024
      Hi, I am using 2025R1 version, circuit mode to do a Nexxim transient simulation. I encountered an error: serializer::iff_writer(error): File layout grew beyond 4GiB limit. The working frequency is large ~MHz, but I need to do a long-time simulation ~100s. I guess the problem is the output data is too frequent. Is there anyway to reduce the outputting frenquency? I tried increasing the step time ~ 3 orders of magnitude in the analysis control, but the same error still exists. I am sure my disk is large enough with a NTFS format.
    • Takeshi Itadani
      When analyzing in Circuit, analysis results are written to .sdf files, but the maximum file size is limited to 4 GB due to system limitations.
      As a countermeasure, please review the analysis time, analysis steps, etc., and set the analysis settings so that the file size does not exceed 4 GB.
    • shupengli2024
      Is there anyway to bypass the 4GB limitation? or how can I reduce the output frequency to make my file smaller than 4GB?
      For my case, I must simulate up to 100s with a 1MHz sinoidal input. I tried to use different analysis steps (10ns-100us), but the total time can only go up to 0.6s no matter the step length.
    • Gia
      Can you please explain more about why you need to simulate up to 100s with a 1MHz sinusoidal input? - Can you please post an image of your model/schematic?
    • shupengli2024
      Sure, I used a rectifying circuit to study the charging time of a capacitor with AC input. Is there a more proper module to simulate it?
      Otherwise, I am still wondering how to reduce the output frequency to make my file smaller than 4GB? Thanks in advance!
    • Gia
    • shupengli2024
      Here you are.
    • Gia
      Could you also please post a screenshot of the Analysis settings?
    • shupengli2024
Viewing 8 reply threads
