August 29, 2025 at 9:03 pm
alirezaparsay
SubscriberHi everyone,
I am trying to import a faceted model (STL) into HFSS. Before importing, I cleaned the file in SpaceClaim using the AutoFix feature. When I run the "Check Facets" option in SpaceClaim, the geometry checks out fine. However, when I analyze the object in HFSS with the Comprehensive setting, I get the following errors:
Face Error: No face facets
Face Error: Face face inconsistency. Other entity Face_1783
When I switch to the Strict setting, only the first error appears.
This is surprising to me, since I assumed both SpaceClaim and HFSS use the same geometry kernel.
I would really appreciate insights on the following:
STL Conversion in HFSS
I understand HFSS converts STL geometry into its own native CAD format. Does anyone know what this format is? Is it possible to generate this format directly in SpaceClaim so I can inspect it before importing into HFSS?Error Interpretation
What do these error messages (No face facets and Face face inconsistency) specifically mean?Performance with Large STL Files
When importing STL files with a large number of facets, the process becomes noticeably slow. Would it be more efficient to export the geometry from SpaceClaim in another CAD format (instead of STL) to speed up the import process in HFSS?Thanks in advance for your help and suggestions!
September 3, 2025 at 5:02 am
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum.
Ansys HFSS uses Parasolid geometry kernel starting from 2023R1 version. It is possible to save your file in Parasolid format using SpaceClaim. It is recommended to use this format as this avoids unnecessary CAD intercorversions.
It is difficult to comment on the errors without looking at the model. Please note that Ansys personnel cannot access files shared though this forum because of export guidelines. You can submit a case through ACSS portal if you have support eligibility where we can provide one to one assistance.
Best regards,
Praneeth,
Click here to join Electronics Community and build a network,
Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
4592
1494
1386
1209
