3D Design
3D Design
STL file import to Ansys Fluent
    • dungnguyenxuan199566
      Hello everyone,
      Does anyone try to import STL file into Fluent for further analysis? Would you please show me how to do that?
      First I tried to import STL file into Fluent Meshing:
      Then when I tried to switch to solution it showed like this:
      Does anyone know how to import STL file into Fluent for airflow analysis?
    • Keyur Kanade
      Please import STL in Flunet Meshing. You can use watertight workflow to generate volume mesh and then switch to Fluent solver.
      Please go through help manual for more details
      Please check following videos
      Fluent Meshing Watertight Workflow:
      https://www.youtube.com/watch?v=aBxbYRVoRLo
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
      Hi Keyur,
      I tried that but Fluent meshing showed something like this. It does not support STL.
      Do you know anyway to counteract this?
    • Keyur Kanade
      Quick workaround - open STL in SpaceClaim. Save .scdoc file. Import scdoc file in Fluent Meshing.
  • The topic ‘STL file import to Ansys Fluent’ is closed to new replies.
