3D Design
3D Design
Stiffness analysis
    • lukin.allgeier
      Good day
      Im currently doing an analysis in Ansys on a base and im trying to get the stiffness results N/m, how would i go about it and what Solution do i use, im very new to Ansys, i have added Moments to the base and also fixed supports, im not sure how to go about the simulation to get stiffness output.
      Regards
      Lukin
    • Charudatta Bandgar
      Hello Lukin ,
      I did not understand your query properly. To help you out with your query, there are few things I would like to know such as,
      • Which discovery product are you using?
      • Have you gone through the tutorials for the discovery product you are using to simulate your problem?
      With the tutorials, you will get an idea, on how to simulate a problem and what results to expect out of it.
      You can also refer to the Documentation for Discovery AIM and for Discovery LIVE on the customer portal.
      For any further help, I will be happy to assist you.
      Regards.
    • lukin.allgeier
      Good day
      Thank you for your reply, i am currently working on workbench and mechanical, i need to simulate a base design but i need stiffness as a result see screen shot, i need to find out what stiffness this base can handle in N/m (Stiffness)
        Hello Lukin ,
        I am really sorry for the inconvenience.
        Regarding your questions on ANSYS workbench and mechanical, please post it on ANSYS Student Community or ANSYS Customer Portal based on the type of license that you have.
        This forum is specifically intended for seeking assistance on ANSYS Discovery products. Thank you for your understanding!
  • The topic ‘Stiffness analysis’ is closed to new replies.
