November 19, 2018 at 2:20 pm
Roberto
SubscriberHi
what is the difference of a step file depending on these protocols?export protocols 203/214/242
Regards
November 19, 2018 at 10:09 pm
Brian Bueno
Ansys EmployeeRoberto
I found this information on the internet:
Generally, AP203 is a "general" STEP format.
AP203 defines the geometry, topology, and configuration management data of solid models for mechanical parts and assemblies. This file type does not manage Colors and Layers.
AP214 has everything a AP203 file includes, but adds colors, layers, geometric dimensioning and tolerance, and design intent. AP214 is considered an extension of AP203.
STEP AP242 Standard
The standard STEP AP 242 (ISO 10303 AP242) “Managed model based 3D engineering" is the merging of 2 ISO standards:
- Aerospace's STEP AP203 "Configuration controlled 3D design"
- and Automotive's STEP AP214 "Core data for automotive mechanical design processes"
STEP AP242 capabilities
Geometry
- Exact shape representation, which is use in the current CAD tool implementing in STEP AP214 and STEP AP203
- Tessellated shape representation. This representation is new in STEP. It allows display efficiently the 3D shape by using a simplified representation (example: triangulated faces).
PMI
- Graphic presentation : The advantages of graphical Presentation are that since it is rendered, it is presented in the STEP file exactly as it was in the CAD system. Since the instantiation is done using basic geometric entities, basically every viewer or CAD system which finds the link in the file structure can display it. The PMI is stored in STEP using geometric entities:
- polylines (points, curves,...) , already use in STEP AP214
- or tessellated , new in AP242
- Semantic representation: Geometric Dimension and Tolerance are stored in the STEP file in parametric. After exchange, it allows the interpretation and the modification like in the native CAD system.
Assembly
- Assembly and Part geometries in the same file
- Assembly with expternal reference to 3D geometry file (in STEP or other format)
- Nested assembly
November 20, 2018 at 8:13 am
Roberto
Subscriberthank you
- The topic ‘Step protocols difference’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
- Discovery 2025r2 failed to initialize
4167
1487
1363
1194
