November 26, 2024 at 3:05 am
jonmshank126
SubscriberWhen I export step files from zemax they don't appear to be formatted correctly. The header section looks like this -
ISO-10303-21;HEADER;/* File generated by HOOPS Exchange Version 22.0.20 */FILE_DESCRIPTION(('HOOPS Exchange Step'),'2;1');,'2024-11-24T14:18:02-08:00',,('Unknown organisation'),'HOOPS Exchange 2022.0','HOOPS Exchange','Unknown authorisation');FILE_SCHEMA( ('AP242_MANAGED_MODEL_BASED_3D_ENGINEERING_MIM_LF {1 0 10303 442 1 1 4 }') );ENDSEC;vs from my professor or step files created in solidworks -ISO-10303-21;
HEADER;
FILE_DESCRIPTION(('STEP AP214'),'1');
FILE_NAME('Cooke 40 degree field modified.stp','2023-09-23T22:31:11',(' '),('ZEMAX'),'Spatial InterOp 3D',' ',' ');
FILE_SCHEMA(('AUTOMOTIVE_DESIGN { 1 0 10303 214 1 1 1 1 }'));
ENDSEC;Any ideas what settings are messed up in my Zemax? I can get the step file to import into solidworks but it isn't quite right. -
November 28, 2024 at 8:01 am
Niki Papachristou
Forum Moderator -
November 28, 2024 at 9:33 pm
jonmshank126
SubscriberTurning off the parasolid libratries creates a header like this –
ISO-10303-21;
HEADER;
FILE_DESCRIPTION ((), ‘1’);
FILE_NAME (‘ ’, ‘2024-11-28T13:21:28’, (‘Unknown’), (‘Unknown’), ‘HarmonyWare STEP v2.0.6’, ‘HarmonyWare Translators’, ”);
FILE_SCHEMA ((‘CONFIG_CONTROL_DESIGN’));
ENDSEC;Still not quite right.
I have the same settings on Zemax 2023 on my work computer and it works fine. For school we have 2024 R1.03, did somthing change between these 2 versions for STEP files?
January 29, 2025 at 2:55 pm
Niki Papachristou
Forum ModeratorHi Subscriber,
I am not too sure what might have changed between the Student versions. I would also suggest to try the latest version 2025 R1, and see if you get the same results: Ansys Zemax OpticStudio Student - Free Software Download
Kind Regards,
Niki
4597
1495
1386
1209
