March 27, 2023 at 12:52 pm
Nicolas Fontaine
SubscriberHello,
I am pretty new with Ls-Dyna. I have a simulation working in two steps: a tube is plastically compressed, then it is compressed again but in another direction. The displacements of the compressing objects are defined with the function "Curve".
I would like first to simulate only the first compression, verify if it works, then simulate with the 2nd compression. Like this, I can avoid simulating the whole thing just to find out that there is a problem in the very first steps. It is a multiple hours simulation...
Is there an easy way to do that? A step-by-step simulation?
Thank you very much for reading me!
Nicolas
March 27, 2023 at 1:22 pm
Prasad Reddi
SubscriberHi Nicolas,
You can try like this using Static or Transient Dynamic state considering that the load application is Displacement approach:
- Using *BOUNDARY_PRESCRIBED_MOTION_SET if Displacement apporach (input load as Displacement vs Time). In this approach, you can extract the REACTION FORCES for either a set of nodes or if using an Impactor, you can extract the contact force to see the output FORCE needed for that APPLIED DISPLACEMENT
- Using *LOAD_NODE_SET if Force approach (input load as Force vs Time)
In both cases, you can assign a load curve which you are defining using *DEFINE_CURVE.
Once the model is stable and working as you require, you can further model another load step using both the options.
Please let me know once you tried these options. Hope this will help you.
~Prasad
March 27, 2023 at 1:36 pm
Armin
Ansys EmployeeHi Nicolas,
You can also check the forum thread below where this topic is discussed:
/forum/forums/topic/error-using-dynain-file-for-sequential-simulations-with-beams-runaway-velocity/Â
March 28, 2023 at 9:38 am
Nicolas Fontaine
SubscriberThank you, both! I will try it and come back to you :)Â
May 26, 2023 at 11:14 am
Nicolas Fontaine
SubscriberHi,
Sorry for my late answer.Â
@Armin_A I checked your link but it didn't really help me with my problem. But thank you!
@Prasad How do I extract the reactions forces and what do I do with them then (sorry, I am still a beginner with Ls-Dyna)? Which functions should I use to do this? I am using Displacement vs time approach and *Boundary_Prescibed_motion_rigid by the way.
Thank you for your time.
~Nicolas
- The topic ‘Step-by-step simulation’ is closed to new replies.
5639
1885
1403
1303
