June 23, 2021 at 4:07 pm
holdy97
SubscriberHello,
I am having an issue that I can't figure out. I am solving axisymmetric diffusion through a sphere submerged in flow. First, I ran the simulation for the steady state velocity profile outside the sphere. I want to use this as the inital condition for the transient diffusion problem. When I load the case and data files, the SS fluid profile is correct - I then turn OFF the viscous flow model and TURN ON my user defined transport equations. The problem is that when I try to initialize for the UDS simulation, it wants to initialize the axial and radial fluid velocity as well which then overwrites the SS profile that I want to use.
I can't figure out how to get around this. Any help would be great. Thanks
June 23, 2021 at 5:49 pmholdy97
SubscriberFigured it out. Do not initialize after solving the viscous flow to prepare for transient diffusion, instead just use "patch" to initialize the appropriate diffusive boundaries
June 24, 2021 at 9:59 amRob
Forum ModeratorYes, if you run a model to get a flow field for a further calculation you do not re-initialise it. I do suggest patching any variables for models you switch on to ensure they all have a value before running on: good to see you've done that.
Viewing 2 reply threads- The topic ‘Steady State Velocity Profile for Initial Condition’ is closed to new replies.
3587
1193
1086
1068
952
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
