July 23, 2021 at 9:48 pm
DG89
SubscriberHi everybody,
July 26, 2021 at 1:16 pmkarthik.remella
AdministratorHello What boundary conditions are you using at the other boundaries? There is a hot spot in your domain towards the bottom. Any reasons for that? Can you plot the corresponding temperature plot here?
Karthik
July 26, 2021 at 6:27 pmJuly 30, 2021 at 8:38 amDG89
SubscriberAny idea?
August 11, 2021 at 1:22 pmkarthik.remella
AdministratorHello Apologies for my delayed response!
Please specify boundary conditions on all boundaries. It is a good practice and Ansys will respect all the exact conditions you wish to impose. Please impose all boundary conditions and see if the results make sense.
Karthik
December 19, 2021 at 6:39 pmDG89
SubscriberHello Apologies for my delayed response, in turn!
I tried to impose all boundary conditions, but the problem still survive. I also tried to change model (I choosed a very simple one, that is a prism), the materials (default material), the display options (elemental mean), but I did'nt obtain benefits.
December 23, 2021 at 2:28 pmkarthik.remella
AdministratorHello What is your entire geometry? Is this a 2D or 3D run? Can you please help me understand the problem you are attempting to solve?
Karthik
December 27, 2021 at 6:06 pmDG89
SubscriberOk, let's start with a more simple object:
A prism, 0.1m hight, 1m long, 1m large
standard steel material
3d solid body
Steady standard thermal analysis
Convection in two opposit faces, while the others four are perfeclty insulated.
The PDF shows some windows of setting parameters and some results. As you can see, even if the object is very simple the directional heat flux along the z axix (please, refer to the images in the file) is not uniform in the y direction, and the same occurs for the temperature. Moreover, the direction flux along the x is very "strange", while I'm expecting it whould be zero, according to the inputs. Curiously the higthest and the lowest values are the same, in absolute value.
December 28, 2021 at 1:20 amDecember 30, 2021 at 5:51 pmDecember 30, 2021 at 6:49 pmpeteroznewman
SubscriberArchive your latest model and attach it to your reply. I will rerun that in ANSYS 2021 R2. Maybe the 7 year old solver doesn't give the same result as the latest solver.
December 30, 2021 at 9:00 pmDecember 30, 2021 at 9:05 pmJanuary 8, 2022 at 4:28 pmDG89
SubscriberGood afternoon,
May anyeone try to fix my second problem? Thankyou.
January 8, 2022 at 4:30 pmDG89
SubscriberI remember that the problem is the unsymmetry in the directional heat flux along the z axis, despite the boudary conditions and the geometry.
Viewing 14 reply threads- The topic ‘Steady state thermal simulation – unsimmetrical results’ is closed to new replies.
