November 12, 2024 at 4:27 pm
filip.chelkowski
SubscriberHi All,
I am using student version of ANSYS Workbench 2024 for my master's thesis. I am trying to model a helping hand bracket on a concrete substrate and see how the temperature changes and hwo the thermal conductivity/temperature chart looks like.
When I import geometry it worked just fine at the beggingin but now I am getting this error constantly:
After that the model space is just gray.
I went back to the project I've started before where mdoel generated just fine and I was able to set boundary conditions such as different temperature on concrete face and on brackets arm face:
I've also run calcualtions and have results for this one:
When I've tried to change the temperature on one side of the model it stoped working. Solver shows error and I can't get results. Before that all I had to do was to start a new project. Not ideal as it takes time to set all engineering data etc. but at least it worked. Now I am encountering that model error and can't even start a new project.
Did anyone encountered this issue as well? Is there any way to fix it? ANSYS 2022 worked just fine and I was able to complete my engineering thesis with it. This time I had to switch to Dlubal RFEM because new version of ANSYS wasn't even able to generate mesh on a bracket (same model as before!). Now I've sipmlified the geometry, mesh generates just fine but the issue with importing geometry and solving the thing started.
Best,
Filip
November 12, 2024 at 5:39 pm
