February 12, 2025 at 7:46 pm
rx20729
SubscriberHi,
I have transferred data from a hydrodynamic diffraction system to an upstream static structural system using the hydrodynamic pressure add-on. I am using the static structural system to determine loads within a floating structure (axial loads and bending moments through beams). I would like to represent these loads as RAOs, to show the loading through each beam at each wave frequency and each wave direction. I am wondering whether it is possible to generate these RAOs within Ansys, or will I have to export the data and create these plots myself?
February 13, 2025 at 12:57 pm
Shuangxing Du
Ansys EmployeeYou could directly have the bending/shear force RAOs from Aqwa-Line (Hydrodynamic Diffraction analysis) by defining the mass distribution along an axis.
February 13, 2025 at 1:40 pm
rx20729
SubscriberI see, okay thank you.
Is there a native way within Ansys to generate beam axial load RAOs?
February 13, 2025 at 2:17 pm
Shuangxing Du
Ansys Employee-
February 14, 2025 at 1:18 pm
rx20729
SubscriberGreat, thank you very much!
February 14, 2025 at 4:13 pm
Shuangxing Du
Ansys EmployeeYou are welcome.
6465
