October 25, 2024 at 3:56 am
rani.a
SubscriberHi,
I am performing static structural analysis for an imported design file in .stp format.
I have removed all the existing contacts and re-created all the contacts for the entire assembly with bonded function.I have applied only a force (F1) of 1962N(200kg) lift on the top face and a force(F2) acting as a load inside the body of 833.85N(85kg).
I have not given any supports/displacements or any other inputs.I have turned on the large deflections to ON and made stiffness matrix of all the contacts to 0.01 factor.
Yet, I am getting the below errors/warnings:
Can somebody help with a quick solution!
Rani -
October 25, 2024 at 6:30 am
ErKo
Ansys EmployeeHi
See this video explaining the error messages -
https://www.youtube.com/watch?v=vNmIipMpzDU
Also look at our other free Ansys courses on how to use and set up models correctly.
All the best
Erik
October 25, 2024 at 7:35 am
rani.a
SubscriberHi,
Got it thanks!
Will check and get back if i find any further issues! -
October 25, 2024 at 5:36 pm
jhicks
SubscriberYour model is basically flying to infinity because you're not constraining it with an displacements or fixed supports. Thats why your UY value at node 303358 is 2M+
5819
