结构
结构
Static Structural 计算的变形后的几何导入spaceclaim
    • Huadong Sun
    • Huadong Sun
      Follow the below procedure:
      -1. First run Static Structural with solution containing desired deformation results. In Analysis setting’s keep Save DB option on.
      -2. Link solution to a new Mechanical Model, and then link this Mechanical Model to Geometry.
      -3. Update the Mechanical Model & open the geometry in SpaceClaim.
      -4. Generate the part in SpaceClaim, Click on file and export the geometry as a .stp format.
      -5. Import the .stp format geometry in SpaceClaim (standalone system) and use save as option to save the geometry as .dwg file format.
  • 主题 ‘Static Structural 计算的变形后的几何导入spaceclaim’ 已关闭新回复.
