November 20, 2024 at 2:54 pm
lis29
SubscriberHi, I'm new to Ansys and having trouble with this sim.
The model consists of multiple parts held together by solid body bolts with simplified cylindrical shafts and T-nuts
Realistic contacts:
Nuts are bonded to bolt shafts with a tiny gap in between
Bolt head contacts with gussets are frictional, 0.2 coefficient
Nut contact with beam is frictional, 0.2 coefficient
Bolt shafts to gusset and beam walls is frictionless (basically the bolt hole)
Parts held together by physically modeled bolts have frictional contacts between them if they’re directly connected by a fastener and frictionless otherwise
All parts without physically modeled bolts are bonded
Boundary conditions are two fixed supports where the model is cut off, plus a planar symmetry boundary condition
500N force upward
Fixes attempted
Gradual load stepping from 50N to 500N over 10 steps
Increased substeps to 250 initial, 100 minimum, 500 max
Removing mesh controls and using a very fine mesh
Fixed red contacts in contact tool
Large deflection on and off
Any advice would be greatly appreciated!
Bolt geometry example (bolt head, gusset, nut, and 80/20 extrusion beam)
Failed convergence result
Original mesh
Meshing with no controls, 5 or 10 mm element size
Bolt locations shown using bolt pretensions, which I turned off at some point -
November 20, 2024 at 6:21 pm
Dennis Chen
SubscriberHonestly, I doubt anyone can just see a few images and your description and figure out what's causing convergence issues lol.  There are a few steps you can take
1) turn on NR residual under solution information (set number to 2 or 4 instead of 0 at default), this allows you to narrow into where the convergence issues have occurred, which provides you with clues if it's related to contact or other factors
2) maybe copy paste your solve.out file's last few lines before the job terminated, that may provide some clues.Â
Best of Luck
November 21, 2024 at 5:24 pm
lis29
SubscriberI turned NR residual to 4 and the simulation still crashed, but got much further than it did before. I'm attaching the solutions branch contact tool here, as well as the last few lines of the solver output file. What's the best way to evaluate what's causing the convergence issue?Â
   EQUIL ITER 22 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1951E-01
    DISP CONVERGENCE VALUE  = 0.1951E-01 CRITERION= 0.7500E-02
    LINE SEARCH PARAMETER =  1.000    SCALED MAX DOF INC = 0.1951E-01
    FORCE CONVERGENCE VALUE =  1.808     CRITERION=  4.455    <<< CONVERGED
   Writing NEWTON-RAPHSON residual forces to file: file.nr001
   EQUIL ITER 23 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2220E-01
    DISP CONVERGENCE VALUE  = 0.2220E-01 CRITERION= 0.8610E-02
    LINE SEARCH PARAMETER =  1.000    SCALED MAX DOF INC = 0.2220E-01
    FORCE CONVERGENCE VALUE =  1.954     CRITERION=  4.546    <<< CONVERGED
   Writing NEWTON-RAPHSON residual forces to file: file.nr002
   EQUIL ITER 24 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2525E-01
    DISP CONVERGENCE VALUE  = 0.2525E-01 CRITERION= 0.9872E-02
    LINE SEARCH PARAMETER =  1.000    SCALED MAX DOF INC = 0.2525E-01
    FORCE CONVERGENCE VALUE =  7.778     CRITERION=  4.638  Â
   Writing NEWTON-RAPHSON residual forces to file: file.nr003
   EQUIL ITER 25 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2590E-01
    DISP CONVERGENCE VALUE  = 0.2590E-01 CRITERION= 0.1113E-01
    LINE SEARCH PARAMETER =  1.000    SCALED MAX DOF INC = 0.2590E-01
    FORCE CONVERGENCE VALUE =  6.809     CRITERION=  4.647  Â
   Writing NEWTON-RAPHSON residual forces to file: file.nr004
   EQUIL ITER 26 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2953E-01
 *** ERROR ***                          CP =  15009.078  TIME= 08:13:14
 Solution not converged at time 4.14475 (load step 5 substep 5).       Â
 Run terminated.  ÂÂ
ÂAfter this, there were a number of summary for contact pairs, and then this:Â Â Â Â Â Â Â Â R E S T A R TÂ Â I N F O R M A T I O N
 REASON FOR TERMINATION. . . . . . . . . .UNCONVERGED SOLUTION                  Â
 FILES NEEDED FOR RESTARTING . . . . . . . file0.Rnnn
                                           file.ldhi
                                           file.rdb
 TIME OF LAST SOLUTION . . . . . . . . . . 4.1437  Â
   TIME AT START OF THE LOAD STEP . . . . 4.0000  Â
   TIME AT END OF THE LOAD STEP . . . . . 5.0000  Â
 NOTE: FOR CONVERGING SOLUTIONS, ADDITIONAL EQUILIBRIUM ITERATIONS MAY BE
      ADDED IN THE RESTART (NEQIT COMMAND) USING THE RESTART FILE file0.Rnnn        Â
 ALL CURRENT MAPDL DATA WRITTEN TO FILE NAME= file.db
 FOR POSSIBLE RESUME FROM THIS POINTÂ
 NUMBER OF WARNING MESSAGES ENCOUNTERED=        17
 NUMBER OF ERROR  MESSAGES ENCOUNTERED=         4Â
 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
November 21, 2024 at 5:36 pm
Dennis Chen
Subscriberunder solution information, there should be contours that let you know where the convergence issue occurred. From there, you can further troubleshoot.Â
November 21, 2024 at 5:42 pm
lis29
SubscriberDo you mean visual contours like in the total deformation results or some information in the solver output text file? The total deformation result looked like this:
In the animation, the deformation looks really good until the part highlighted in orange and red just detaches upward from the rest of the body at time step 5.
