Static Structural 2D line body importing problem.
    • Bilal Akdağ
      Hello, My license is 2023 R2 educational. I have a problem with importing body in static structural section. Im a solidworks user on CAD side, Just created a bridge made of lines, exported it as step file and tried to import into geometry.
      this is the response I get
      And this is the line body I wanted to import
      This is the response I get when I create same sketch with design modeler:
      Please help.
    • Ankush Choudhary
      • Bilal Akdağ
        I am not sure if my problem is related to that. My problem can be simplified as 2D.
    • ErKo
      Hi
      As mentioned in properties (Analysis Type) you need to set it to 3D as beam/lines will not work with 2D option.
      To have 2D in the 3D analysis then just fix the Z - direction on all nodes and the ROTX and ROTY.
      Set a snippet with:
      D,ALL,UZ,0
      D,ALL,ROTX,0
      D,ALL,ROTY,0
      That makes it 2D in principle
      • Bilal Akdağ
        Tried it in 3D too. Still did not work. I found the reason. There was no cross section dimensions. So when I attached a cross section dimension to sketch by design modeler, it worked. But I need something faster. A step file to be imported in sketch so I can define a cross section dimensions in the inside of ansys.
  • The topic ‘Static Structural 2D line body importing problem.’ is closed to new replies.
