December 29, 2020 at 5:56 am
Van Toan Nguyen
SubscriberHi everyone,nI am now using Static Structural module (Workbench) to obtain thermal expansion. There is only the effect of Body temperature changed in time. Do I need to use Transient Structural module? Because the temperature load is time dependent.n -
December 29, 2020 at 2:01 pm
peteroznewman
SubscribernIf you only care about the themo-elastic strain created when the temperature changed from one value at T=0 to another at the End Time, you don't need Transient, even if the Thermal analysis was transient.n -
January 1, 2021 at 1:30 pm
Manatee
SubscriberThat depends what you are looking at exactly. The transient solver solves each time step, so you will get information for every time step. How important is the exact behavior over time? If you want to look at thermal expansion after e.g. 5 minutes, the solutions for transient and steady-state might be similar if you have already reached an equilibrium at that point. If not, the solutions might be very different.n -
January 1, 2021 at 2:02 pm
Van Toan Nguyen
Subscriber@ToanNguyen If you only care about the themo-elastic strain created when the temperature changed from one value at T=0 to another at the End Time, you don't need Transient, even if the Thermal analysis was transient./forum/discussion/comment/101369#Comment_101369
Thank you for your reply. I want to know values of the relative displacment caused by thermal expansion and other forces at differen time points. ( There are different values of temperature at diffenrent time steps). n -
Van Toan Nguyen
SubscribernThat depends what you are looking at exactly. The transient solver solves each time step, so you will get information for every time step. How important is the exact behavior over time? If you want to look at thermal expansion after e.g. 5 minutes, the solutions for transient and steady-state might be similar if you have already reached an equilibrium at that point. If not, the solutions might be very different./forum/discussion/comment/101595#Comment_101595
January 2, 2021 at 12:28 am
Manatee
Subscriber@ToanNguyen nI think in that case it would be best to run it as a transient analysis.n -
January 8, 2021 at 11:49 am
sars
SubscriberHello dear friendsnI have some question about nonlinear analysis in transient structural.nI want to analysis a simple model of turbine with 8 sector in ansys, There is frictional contact between blads. preload and rotation velocity must be defined in static structure and traveling wave excitation is applied in transient structure.n1) Do you know that how can apply cyclic symmetry constraint in transient analysis? n2) How can I do the transient analysis after the static structure analysis under the preload and rotation velocity? nplease guide me.Thanksnsarann -
January 8, 2021 at 1:10 pm
January 8, 2021 at 1:28 pm
sars
SubscriberHi Mr.peteroznewmannI will definitely do this. nDo you have a suggestion for my problem?n
- The topic ‘Static or transient structural analysis!’ is closed to new replies.
3597
1283
1107
1068
978
