Static analysis of orthotropic material
    • wojciech.bissinger
      Hello everyone, I have a question regarding presenting stress results in a static analysis. I analysis an aircraft wing rib made of plywood. If I classified the material as orthotropic and provided the appropriate strength data like Young modulus, Shear modulus and Poisson ratio, can I present the stress results as Huber-Mises stresses?
      Thanks for help
    • ErKo
      Hi
      We do not have such a stress result.
      We have von Mises stress results.
      Is that what you mean?
      If not:
      Can you explain and give some references / (e.g., equations) on this type of stress (Huber-Mises stress)?
      Then perhaps forum members might be able to give some more feedback.
      thank you
      Erik
  • The topic ‘Static analysis of orthotropic material’ is closed to new replies.
