February 6, 2025 at 9:05 am
sikandarafzal499
SubscriberI have this rectangular cross section hook which i will use to pick up some kind of a weight, The boundary conditions that i have applied are:
1) The top end is a fixed support.
2) I have used a remote force to simulate the load applied on the hook, where i selected the whole area that in my opinion is affected by the force and than for applying the remote force i use location variable to select the area where the load will be applied, its a vertically downward acting load. Is my approach correct or no.? -
February 7, 2025 at 6:16 am
Sourabh Upadhyay
Ansys EmployeeHi Sikandar,
As I can see in this case you are applying two loads, may I know the reason?
The entire structure will be affected by load but we need to scope the area or edge on which the load is applied.
Sourabh
2778
965
841
599
591
