December 21, 2022 at 12:37 pm
Biborka Boga
SubscriberHi! I am trying to perform the initialization via TUI through a journal file. I have a multiphase problem (two phases), and previosuly I have defined also a cell register (region0).
After initialization I have performed the patching of VOFÂ phase 2 to 0.99 in the previously mentioned cell register.
Can you please let me know how can I mention this patching in the journal file?
In the Ansys Fluent Text Command List I have found: solve/initialize/vof-patch-smooth-options/ as a text command for patching, however in this case I do not know how to specify the region, phase, etc.
My assumption looks like, however unfortunately this does not work
/solve/initialize/vof-phase2=0.99-region0-patch/
Can you pls offer me some hints how can I write this text command in an appropriate way?
Thank you very much in advance!
December 23, 2022 at 5:05 am
Keyur Kanade
Ansys EmployeePlease check /solve patch
Please go through help manual for more detailsÂ
Keyur
December 23, 2022 at 7:36 am
Biborka Boga
SubscriberThank you very much your response!
Best regards,
Biborka
- The topic ‘Standard Initialization and patching via TUI- journal file’ is closed to new replies.
- affinity not set
4042
1461
