October 29, 2021 at 11:58 am
gindi
SubscriberHello,
As can be seen in the attached image, the pipe outlet is initialized with air even if i set the whole domain as water (setting water volume fraction = 1). I tried patching also but with no luck.
The outlet boundary condition is set to mass outlet flow with air mass flow = 0 and water mass flow = 22 kg/s.
October 29, 2021 at 1:36 pmRob
Forum ModeratorWhat did you set the initial volume fraction as, and what zone/register did you patch?
October 29, 2021 at 2:17 pmgindi
SubscriberI tried:
1) setting the initial volume fraction for water = 1, and patching air region as water volume fraction = 0.
2) setting the initial volume fraction for water = 0, and patching water region and pipe region as water volume fraction = 1.
Both ways gives the same result.
The odd thing is that I have a similar model but without the floor slope that doesn't have this issue. I tried reconstructing the geometry again as I though i might have missed something but still the same issue persists.
October 29, 2021 at 2:32 pmRob
Forum ModeratorCan you check the boundary labels and cell volumes to make sure the zones are as expected? If the other model works I wonder if you missed a volume when setting labels.
October 29, 2021 at 2:41 pmgindi
SubscriberI did that actually. Exactly the same as the one I had earlier. Three fluid zones named as I mentioned earlier, and the boundary conditions set similar to those I had before.
I will give it another try and rebuild the whole model again as a recheck. I will keep you posted.
October 29, 2021 at 4:12 pmRob
Forum ModeratorCan you check you patched the correct fluid domains? The obvious hiccup is not patching the top cylinder.
October 29, 2021 at 4:28 pmgindi
SubscriberI understand your reasoning, but this should not be the case if I initialized the whole domain with water volume fraction = 1. Then patching the air region, where the pipe is not part of it.
Any way, I reconstructed the whole geometry for the third time and remeshed it again. now it seems that the issue has gone. I will try to debug it step by step and compare with the old problematic one to check again where I went wrong.
Thanks for your support.
Viewing 6 reply threads- The topic ‘Standard Initialization and Patching is not applying at the boundary’ is closed to new replies.
5939
1307
