May 24, 2023 at 5:45 am
sree-ranjini.kizhakkethil-swaminathan
SubscriberWhat is the difference in defining stacking factor in saturation and in active length of MOTORCAD? Which method must be followed under what circumstances?
June 5, 2023 at 1:20 pm
Bo Ren
Ansys EmployeeHello Sree,Â
Stacking Factor Calculation In Motor-CAD has three types, which areÂ
Ignore Stacking Factor - no account is taken of the stacking factor.
Stacking Factor (axial length) - the axial length of the machine is reduced in the FEA calculations to account for the stacking factor.
Stacking Factor (saturation) - the BH curves for the stator and rotor steels are adjusted to take into account the stacking factor.
Stacking Factor (saturation) theory
An equivalent homogenous material with the same properties as the entire stack is created.
The equivalent permeability of the homogenous material becomes:
μeq = kst x μiron + (1 - kst) x μ0
The magnetic flux density of homogenous material for specified magnetic field becomes:
Beq = μeq x Hiron
where
kst = stacking factor
μiron = permeability of iron
μ0 = permeability of free space
μeq = permeability of homogenous material
Beq = magnetic flux density of homogenous material for specified magnetic field
Hiron = magnetic field
The employment of the stacking factor consideration methods in Motor-CAD depends on the simulation needs. The default setting is recommended. Â
ThanksÂ
Best regards
Bo REN
- The topic ‘Stacking Factor definition’ is closed to new replies.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Core Loss in ANSYS MAXWELL Eddy Current solution
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- simplorer-maxwell
4673
1565
1386
1231
