March 18, 2024 at 11:32 am
March 18, 2024 at 1:16 pm
Federico
Ansys EmployeeThis is only a warning. If you find the message only appears in the first few iterations and goes away, you might be Ok to just ignore it. If the message persists, than it could indicate that your solution is not stable.
March 19, 2024 at 12:33 pm
omar.ennaya
SubscriberIt is staying and desappearing simultanately.
What should do in this case.
Thank you for your interaction by the way.
March 19, 2024 at 6:37 pm
Federico
Ansys EmployeeAs per my previous message, if it disappears after a few iterations, you may ignore this.
Also, pay close attention to your residuals and ensure they are steadily decreasing.
- The topic ‘Stabilizing pressure message’ is closed to new replies.
1885
1403
1298
