September 27, 2023 at 4:00 pm
Abbas Kadhir Ali Mohamed Abbas
SubscriberHi,
I have a 2D axisymmetric model where I have a contact spring setup and wanted to understand the dynamics of a part under force. I also wanted to do a parametric study with different stiffness values and their effect on the dynamics of the part. But when I plotted the deformation of the part under various stiffnesses ranging from 200 N/mm to 500 N/mm, all the deformations were exactly the same.
I did a similar sensitive study with ranging preloads which worked but changing stiffnesses did not work. Does anyone know the reasoning and solution?
P.S. I tried setting up the Spring contacts in the respective coordinate system of contacts rather than Global. Did not work either.
keenly await your suggestions
Best Regards,
Kadhir -
September 29, 2023 at 2:07 pm
Ashish Khemka
Forum ModeratorHi Kadhir,
Can you please share snapshots of your setup?
Ashish Kumar
September 29, 2023 at 10:51 pm
- The topic ‘Spring Contact in 2D Axisymmetric’ is closed to new replies.
2778
965
841
599
591
