Spray Cooling Issue
    • System_delete
      This discussion was created from comments split from: DPM modelling.
    • Milhm
      Hi,nnI am working on spray cooling.I want to spray water in a compressible flow.The stagnation pressure is 4Mpa and static pressure is 0.696Mpa.I set operating pressure to zero and i enter 4Mpa and 0.696Mpa in pressure inlet boundary conditions.I enabled species transport.In materials for mixture template, i select ideal gas for density, mixing law for Cp and Sutherland Law for viscosity.I use pressure swirl atomizer.nnAt the beginning of injection i recieve this error:# Divergence detected in AMG for pressure coupled: protective actions enabled!nn# Divergence detected in AMG for pressure coupled, temporarily solve with BCGSTAB!nnError: Divergence detected in AMG solver: pressure couplednnWhat should I do?what is wrong?.nnRegardsnnMiladn
    • DrAmine
      Add more information about your case and switch off injection at first. Run single phase!n
  • The topic ‘Spray Cooling Issue’ is closed to new replies.
