splitBody.Bycutter()
    • haibin wu
      I try to use the command “splitBody.Bycutter()” to cut my main body and hollow pipe. My main body is shown in the figure below. This main body is a solid body. I first cut out a hollow pipe with scanning. Now I want to put This pipeline is separated from the entity cutting. I can achieve this function in the operation interface, but when I use the code: “splitBody.Bycutter(bodySel, edgeSel)”, I get an error: “no tools selected”. In “edgeSel”, the ring edges at both ends have been selected. I don't know where the problem is, can you explain it for me? thanks for your help
    • Sampat Kumar
      Hi haibin,
      Please try to avoid creating a duplicate question. I am considering the latest post as your correct one and I am closing this forum thread. Further discussion related to this post will be on the below-mentioned forum thread.
      /forum/forums/topic/splitbody-bycutter-in-scdm/
      Sampat
  • The topic ‘splitBody.Bycutter()’ is closed to new replies.
