July 3, 2023 at 5:46 pm
Andrew Walsten
SubscriberIn the past, I have used ANSYS HFSS to simulate the electromagnetic responses of a split-ring resonator (SRR) with a supplied microwave signal. Recently, I ran an experiment where I was running a SRR that was placed in an external magnetic field created by a couple permanent magnets. As far as I know, I cant create a static magnetic field in HFSS. Does anyone know how I could simulate the SRR electromagnetic response in an external magnetic field? Any help or advice would be appreciated. Thank you.
July 5, 2023 at 9:48 am
dushyant.marathe
Ansys EmployeeÂ
Hi Andrew,
Thanks for posting your query on Ansys Learning Forum. I would like to know additional information regarding your simulation setup. Are you using any Ferrite Materials in your simulation ? Thanks.Â
July 5, 2023 at 4:46 pm
Andrew Walsten
SubscriberThe simulation would contain the SRR with a lumped port supplying the signal. There would also be two rare earth magnets that are ring shaped.Â
The magnets would be creating a static magnetic field that the SRR sits in. From what I've read, you use Maxwell for static fields, but I also have the SRR with the lumped port. Is there a way to have the magnets in HFSS or maybe simulate the static magnetic field in Maxwell and then somehow import that into the HFSS simulation?
July 7, 2023 at 4:08 am
dushyant.marathe
Ansys EmployeeHi Andrew,
Thanks for sharing more details regarding your setup. HFSS only allow assigning magnetic biases to Ferrite materials. To assign non-uniform magnetic bias a setup link can be esatblised to Maxwell magnetostatic steup. However, in my opinion standalone magnet simulation in HFSS or taking its effect from Maxwell is not possible.
Thanks.
- The topic ‘Split-Ring Resonator in a Magnetic Field’ is closed to new replies.
5719
