July 7, 2020 at 1:53 pm
dk89
SubscriberHi all,
I have generated the mesh for a rotor domain (compressor blade) with Turbogrid. I want to split the blade geometry to suction and pressure side in Fluent. I tried to separate the blade geometry by angle in Fluent, but it didn't work. Do you have any suggestion? Thank you for your time.
July 8, 2020 at 12:45 am
Karthik Remella
AdministratorI think you are doing this the correct way. What do you get when you separate the geometry by angle?
Can you not split the edge in your geometry, mesh, and bring this new mesh into Fluent?
Thanks,
Karthik
July 9, 2020 at 3:42 pm
dk89
SubscriberHi,
When I split the blade geometry by angles higher than 90 deg, the blade is split in two zones. The new surface looks like the blade tip. When I split the blade by smaller angles, many new zones are created, but I cannot distinguish which of them belong to either suction or pressure side of the blade. The distinction of the new zones is very unclear. Thank you.
July 10, 2020 at 5:49 am
Keyur Kanade
Ansys EmployeeYou are on right track.Â
Use smaller angle. Then display the separated boundary zones. Then merge the boundary zones as per necessity.Â
If you want more control on separation then you may need to read case file in Fluent Meshing. Here you can have more control. But all manual. This may need more experience with Fluent Meshing. I can point out to the command.Â
The commands are -Â
Boundary --> Modify --> Rezone.Â
Please check help manual for more details about this command.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘Split boundary geometry in Fluent’ is closed to new replies.
3637
1313
1142
1069
1013
