Preprocessing
Preprocessing
Split a solid body for meshing
    • Emad64
      I am modelling a composite concrete member including 2 different solid bodies. I have a problem with meshing the whole geometry. I am wondering if I can split a solid body into more a set of cuboids to get a nice hex mesh? Does it have any effect on the final result?
      P.S. I tried multizone option and face meshing to generate nice hex mesh but it doesn't work!
      Thanks in advance.
    • Keyur Kanade
      you need to split geometry in spaceclaim or design modeler.
      https://www.youtube.com/watch?v=EJ7DvfzDYwQ
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • Emad64
       Hi Keyur,
      Thanks for your reply. I already split the geometry in SpaceClaim. Just I need to know that the performance of the split body is the same as the original body?
      Thank you
      Assuming the boundary conditions are set up correctly it won't make a difference.
    • Emad64
      Hi Rwoolhou,
      Thanks for your comment. So I will try that.  As you can see in the below picture, ununiform mesh in solid 1 and solid 2 are the main reason for splitting the body into small pieces. I am wondering if there is any other way to get a nice hex mesh without splitting the bodies? In addition, how can I get rid of the warning error?!
      P.S. I tried face meshing but shows "Error in the requested meshing operations"
      Thanks in advance.
    • Keyur Kanade
      to get hex mesh without splitting box is difficult.
      you can try multizone. but still i feel you will need splitting.
      Keyur
    • Emad64
      Thanks Keyur. I'll try that
Viewing 6 reply threads
  • The topic ‘Split a solid body for meshing’ is closed to new replies.
