February 9, 2019 at 4:02 pm
Francois Fosse
SubscriberHi,
Is there a way to convert lines connected together to a rounded corner to a single spline?
Thanks,
Francois -
February 12, 2019 at 5:41 am
subashni.satish
Forum Moderator-
February 12, 2019 at 8:31 am
Francois Fosse
SubscriberHello Subashni
Thanks for your answer, I give it a try but found only the arc is moved to spline not the entire selection (line+arc+line). Do you get same behavior?
February 12, 2019 at 8:51 am
subashni.satish
Forum ModeratorFrancois Fosse
Try increasing the Maximum Distance and make sure you select the lines and the rounded corner
February 12, 2019 at 10:16 am
Francois Fosse
SubscriberYep, it works, need to split lines in small segments for better results also.
Thanks -
March 1, 2019 at 3:26 pm
Roman8
Ansys EmployeeJust another note, if you use fill and click the point between the line and arc you will concatenate the curves into a single polyline.
March 2, 2019 at 10:58 am
Francois Fosse
SubscriberRoman Walsh
Keep this one. Thanks
Viewing 4 reply threads
- The topic ‘Spline conversion’ is closed to new replies.
