July 14, 2026 at 9:29 am
felmoehl
SubscriberHi, i am trying to do some post processing for my Freeflow SPH simulation. Because SPH particle are only a point coordinate and not a volume element, i tried to create an iso volume with a specific radius so that the particle are overlapping as a SPH surface. My idea was that with this setup i should be able to use a clip plane to interpolate the data onto the plane e.g. velocity contures etc. The iso volume works fine but the clip plane is allways empty. Have someone an idea/fix or a workaround for that problem? Thx:)Â
Viewing 0 reply threads
1343
1152
